I could finally resolve the legal issues. Cexp is released under the EPICS Open License. Cexp is a C-expression interpreter with a built-in loader for object files (using the BFD library) - Cexp's primary target is RTEMS. Cexp has built-in support for the basic C types and it supports (typed) user-defined variables. The TECLA line editor which is used by Cexp provides comfortable features like word completion and command history. The loader supports C++ (static constructors, exceptions, "linkonce" sections etc.). I have successfully loaded and executed quite large C++ apps (EPICS) from Cexp running on both, linux (powerpc, x86), solaris and RTEMS (powerpc). Check it out at http://www.slac.stanford.edu/~strauman/rtems/cexp/ -- Till
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
