> locate libreadline Vijayram, I suspect it's looking for the static libreadline.a file, which is in a different RPM on Red Hat at least and is present on our systems here, but evidently not on yours (from your locate output above). If you can install the .a version you'll fix the problem sooner, but we need to fix the EPICS build system too as it's obviously *not* trying to use shared libraries here when it really should be (assuming you haven't changed the SHARED_LIBRARIES setting in configure/os/CONFIG_SITE.linux-x86.Common) - Andrew -- "Life is what happens while you're busy making other plans." - John Lennon
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
