1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Extending MBBO?
To: [email protected]
Cc: tech-talk
Date: Thu, 7 Nov 2002 11:15:21 -0600 (CST)
This has come up often ...
The MBBO record is limited to 16 values because all
enumerated values passed by channel access are limited
to 16 states (MAX_ENUM_STATES). If this is changed, everything
breaks.
There aren't any "perfect" work arounds. Here are two I have
seen used:
1) If you want strings on a menu, define multiple MBBO's to
   cover as many as you need. A unique value can be calculated
   in the database depending on which MBBO changed. Unfortunately,
   all clients that want to use these PVs will have to decide which
   PV to write to.
   For an operator GUI, a TCL/TK application can be written that
   provides ALL menu choices and writes to the appropriate PV.
2) If you can do without strings, use a longout record that can
   then fanout to calc records and mbbo's to determine the
   appropriate action.
   	Ned
> I have a device where I need to select 1 of 22 inputs.  The logical record
> choice is MBBO, but it is limited to 16 values.  Is there a way to chain
> together 2 MBBO records to get more than 16 choices?  Any reason that MBBO
> was limited to 16 values, rather than 32?
> Thanks,
> Mark Rivers
Re: Extending MBBO? Ralph Lange
Re: Extending MBBO? Brian McAllister
Prev: Extending MBBO? Mark Rivers
Next: Re: Extending MBBO? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
