1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS
To: Krishna <[email protected]>
Cc: [email protected]
Date: Wed, 06 Nov 2002 14:27:08 -0600
Krishna wrote:
I am trying to install EPICS R3.14.Obeta2 in my linux
system 86 system.
Is there any specific related information for
installing this release(R.3.14) epics on linux system.
Instructions on "Building EPICS base" are in the documentation/README.html file in the distribution (and also in the R3-14.0beta2 page on the EPICS home page). Specific settings are described in comments the files to be edited.
 There are two directories(config, configure) which
have common files like CONFIG_COMMON, CONFIG_SITE etc.
which directory files should be changes for our
specifications.
The README explains that you only need to edit the config/* files if you want to use the R3.13 compatibility facilities of the build system for any extensions or IOC applications.
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
EPICS Krishna
Prev: EPICS Krishna
Next: building static libraries Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS Krishna
