1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800
To: [email protected]
Cc: [email protected], [email protected], [email protected], [email protected], [email protected]
Date: Thu, 31 Oct 2002 13:05:09 -1000 (HST)
>>>>> "Ned" == Ned Arnold <[email protected]> writes:
 Ned> The short answers are ...
 >> From: "Redman, Russell O." <[email protected]>
 >> My big questions are thus
 >> 1) Under what circumstances does pushing a value over a CA link cause the
 >> target record to process?
 Ned> .... if the destination field is defined as "PP" (with the statement
 Ned> "pp(TRUE)" in the *.dbd file and so documented under the PP column in
 Ned> the record reference manual) and the record scan field is set to
 Ned> "Passive". If these two conditions are true, the record will process
 Ned> when ANY channel access client (including a sequence programs, CA
 Ned> links, etc) writes to that field.
So it is a record type property?  There is no way to vary it per record
instance?
Mahalo,
Jim
Implication -> more special record types :-(
Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Andrew Johnson
Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Ned Arnold
Prev: Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Ned Arnold
Next: Re: Your Message Sent on Thu, 31 Oct 2002 12:25:33 -0800 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
