1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: is there a way to get caRepeater statistics
To: "'Kevin Tsubota'" <[email protected]>, "'tech-talk \(E-mail\)'" <[email protected]>
Date: Wed, 23 Oct 2002 15:22:02 -0600
> Is there a way to get statistics from a running caRepeater?
Sorry, no such interface exists at this point.
There is a program called "casw" in R3.14 that prints
a message each time that a CA server beacon anomaly
is detected.
> We've been experiencing frequent channel access disconnects
I don't expect that a CA repeater failure would be
the root cause of premature disconnects. The CA
repeater's sole purpose is to fan out CA server
beacons to multiple CA clients on the same host,
and if the CA client library does not see any
traffic from the IOC including the IOC's beacon
then it will fall back to polling the IOC
periodically in order to verify its connection.
The more likely root cause of premature disconnects
might be any of the following:
o CPU saturation on the CA server
o Network or IP kernel congestion
PS: If CA clients are not reconnecting to a newly
available IOC then this *is* a symptom of problems
with the CA repeater.
Jeff
is there a way to get caRepeater statistics Kevin Tsubota
Prev: Re: is there a way to get caRepeater statistics Ralph Lange
Next: EPICS R3.14.0beta2 device drivers Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
