1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: problem with EPICS RULES.Host (R3.13.7 but also before)
To: EPICS Tech Talk <[email protected]>
Date: Wed, 16 Oct 2002 13:41:57 -0500
Who can fix this?
Discovered a problem with the R3.13.7/base/config/RULES.Host
while building in the source tree of a top level directory.
In the $(TOP)/topApp/src/Makefile.Host file, there is a directive
DBDINSTALL += ../topShare.dbd
When I issue a
	cd $(TOP)/topApp/src
	gnumake rebuild
in that $(TOP)/topApp/src/ directory, the process fails
with a complaint that it cannot rebuild  topShare.dbd.
Inspection of the directory shows that the process
has deleted the file!
After reinstalling that file, I compare the result with
	cd $(TOP)
	gnumake rebuild
This works properly.
This is not good. This has happened for some time
now (maybe since at least 3.13.0).  I believe this to
be a general problem which is not specific to the
mca5_1/mcaApp/src directory being rebuilt at the time.
Pete Jemian
UNICAT
[email protected]
Re: problem with EPICS RULES.Host (R3.13.7 but also before) Janet Anderson
Prev: EPICS Meeting - Very preliminary Agenda Karen White
Next: Re: problem with EPICS RULES.Host (R3.13.7 but also before) Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
