Ken, I recently made similar changes and sent the changes to DESY and TJNAF - the keepers of the forked code of which we know. I added default .cnf and .dat, and use environment variables to point to default directories. I hope these ideas (and very minor mods) are useful to you. /Ron Chestnut "The direct use of force is such a poor solution to any problem, it is generally employed only by small children and large nations." -David Friedman -----Original Message----- From: Chestnut, Ronald P. Sent: Wednesday, August 28, 2002 2:50 PM To: Chris Larrieu (E-mail); Matthias Clausen (E-mail 3) Cc: Chestnut, Ronald P.; Allison, Stephanie Subject: Some StripTool files - tiny SLAC modification Dear Chris and Matthias, Please find enclosed four files from the StripTool: Strip.c - few lines to support separate DATA storage directory StripDialog.c - few lines to use env variable for CONFIG directory StripDefines.h - few lines to support a default DATA filename extension Makefile.Host - Two lines to set the default CONFIG filename and DATA filename extensions. The two new env variables are STRIPCONFIGFILES and STRIPDATAFILES. If these have values, they are the default CONFIG and DATA locations; if they have no value, the behaviour is as before (current directory for both). I know we are forked, most probably from both of you. This is my poor man's solution to unforking. /Ron Chestnut "The direct use of force is such a poor solution to any problem, it is generally employed only by small children and large nations." -David Friedman Attachment:
Strip.c Attachment:
StripDialog.c Attachment:
StripDefines.h Attachment:
Makefile.Host
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
