1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: old/new MVME-177 compatability
Cc: Paul Sichta <[email protected]>, [email protected]
Date: Thu, 19 Sep 2002 20:53:54 -0600
We also use the Petra MVME-162s at the Sloan Digital Sky Survey,
with the BSP mod Andrew mentioned, and have experienced no
problems.
Andrew Johnson wrote:
> Paul Sichta wrote:
> > I plan to buy a MVME-177 from Motorola in order to have a
> > second spare CPU.  They discontinued production of the model
> > MVME177-013 in August 2000, and now offer a replacement
> > based upon their Petra ASIC.  The part number is now
> > MVME177P-64SE.  Has anyone used the (new) Petra ASIC boards?
> > Are they swappable with the original MVME-177 boards?
> We use Petra versions of the MVME-162 and MVME-172, which are completely
> plug compatible, although they do look a bit different to the older boards.
> > Wind River doesn't make mention of a separate bsp for the
> > new MVME177P .
> The same BSP works with both versions, although there is a one-line change
> that you should probably make (it's not clear whether it's still needed as
> it was a workaround for a bug in the Petra chip that might have been fixed
> in later versions, but as the modified code works with pre-Petra boards
> anyway it's worth making it just in case):
> In the sys596IntDisable() routine (sysLib.c), replace the code
>      *PCC2_LANC_IRQ_CR &= ~LANC_IRQ_CR_IEN;
> with
>      *PCC2_LANC_IRQ_CR &= ~ABORT_IRQ_LEVEL;
> Without this modification it is possible for a busy network to cause the
> network connection to become unreliable, although you might not notice it.
>   I have an similar change in all my mv16x and mv17x BSPs, just to be safe.
> - Andrew
> "Life is what happens while you're busy making other plans." - John Lennon
Peregrine M. McGehee    [email protected]      (505) 667-3273
Sloan Digital Sky Survey / Spallation Neutron Source
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
old/new MVME-177 compatability Paul Sichta
Re: old/new MVME-177 compatability Andrew Johnson
Prev: RE: Recommendations for Power PC VME cards Kevin Tsubota
Next: RE: Recommendations for Power PC VME cards David H. Thompson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: old/new MVME-177 compatability Andrew Johnson
Next: Recommendations for Power PC VME cards Dennis Armstrong
