I could successfully load a major C++ application (EPICS example) into a running RTEMS system! Works like a charm. I recently ported my C-Expression interpreter and symbol table utility from libelf to BFD and it now features: - C expression interpreter with a simple type engine (char, char*, int, int*, int(*)(), double...) and access to symbols. - user variables (also typed - can be used to define aliases etc.) - runtime loader; object modules can be loaded to and unloaded from a running system - disassembler (comes free with BFD) Cexp/BFD is pretty portable, the full featured tool works not only on RTEMS but under several ELF platforms (linux-i386, linux-ppc, solaris-sparc). I suppose that the runtime loader needs some porting work when other BFD backends are used. C++ (exception) support is probably limited to gcc (and could unfortunately even be gcc-version sensitive) Nevertheless, working with RTEMS begins to rock... -- Till PS: Alas, I have to resolve annoying licensing issues before I can release this...
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
