1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT fiel d
To: "Kotturi, Karen `Dayle`" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 05 Sep 2002 14:38:14 -0700
Hi Dayle,
Did Ralph's suggestions fix your problem?
I hope...
- Judy
-----Original Message-----
Sent: Thursday, September 05, 2002 5:22 AM
To: Kotturi, Karen `Dayle`
Cc: EPICS Tech-Talk
Subject: Re: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT
field
Hi Dayle,
the alh configuration and command line arguments that you are using seem
reasonable. Also your understanding of how the alh handles the ACKT
fields is correct.
The error message you are getting gives the most detailed hint:
  >   alCaPutGblAckT: ca_put acknowledge transients failed for PV <myPvName>
  >   Return Status: Write access denied
So the CA access that the alh is doing is correct, but the alh doesn't
get write access to the record.
So ...
  > I have removed all security from the IOC (i.e. ASG field for all
  > records is empty).
Here's the important clue:
The ASG field being empty does _NOT_ mean that you removed access
security. It only makes the record use an Access Security Group (aka
ASG) called DEFAULT instead of a specified one.
As long as you load an access security definition file, records with
empty ASG fields will end up using the rules in the DEFAULT group. You
have to comment out the setting of the access security definition file
in your startup script to shut down access security completely for the
IOC.
The only other reason for your alh not to work could be that it accesses
the database through an instance of the CA Gateway which is running in
read-only mode or doesn't have write access defined for your alh client.
When accessing an IOC through a Gateway, only the access security rules
in the Gateway are affecting your client's connection. The IOC only sees
the Gateway as its one and only CA client and has no idea of this being
a proxy serving more than one end user client on the other side.
Hope this helps,
Ralph
>>>>> "Dayle" == Dayle Kotturi <[email protected]> writes:
  > I am running alh (version 1.2.9 or 10) in global and active mode. I have
  > removed all security from the IOC (i.e. ASG field for all records is
  > empty).
  > I want the alarm handler to read the 'T' flags set for a given
  > channel and use them to override the (default) value in the database
  > for the channel (which is ACKT=YES), such that the operator does not
  > have to acknowledge transient alarms, as is the behaviour of alh
  > (version 1.2.2).
  > I understand that the way to do this is to run the alh with -caputackt
  > cmd line option. The expected behaviour is that alh will set all
  > channels' ACKT filed to NO where it finds a 'T' set in the alh config
  > file.
  > To be clear, the command line I am using to start the alh is:
  >     alh -global -caputackt -aCM -oCM -m 10000 alhConfigFile
  > Doing this, I get write access errors (i.e. alh process is not allowed
  > to write this field of the channel/record. Specifically, with R3.13.2, I get:
  > Sorry to be so verbose but there is a recent tech-talk entry from
  > 14aug2002 related to this...
  > On Wed, 14 Aug 2002, Marty Kraimer wrote:
  >> john sinclair wrote:
  >> > Can the ACKS and ACKT fields be modified via
  >> > channel access? When I try, ca_put fails.
  >> ACKS can only be changed via a DBR_PUT_ACKS request.
  >> ACKT can only be changed via a DBR_PUT_ACKT request.
  >> ACKS,ACKT are present for alarm handlers not general purpose CA clients.
  >> Note that access security can be used to limit who/where/when can modify these
  >> fields.
  >> Marty Kraimer
  > I am not sure how to accomplish Marty's suggestion. How do I get the
  > alh to use "a DBR_PUT_ACKT request"? Do I need another version of libca.so?
  > I saw no change using R3.13.6 and have not yet tried with R3.14.
  > thanks for any help,
  > Dayle
Prev: Re: medm problem on LINUX RedHat 7.2 Kenneth Evans, Jr.
Next: Re: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT field Ralph . Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: xy542 and koDevLib Allan Honey
