Subject: |
Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT field |
Dayle Kotturi <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 04 Sep 2002 12:40:38 -0700 (PDT) |
I am running alh (version 1.2.9 or 10) in global and active mode. I have
removed all security from the IOC (i.e. ASG field for all records is
empty).
I want the alarm handler to read the 'T' flags set for a given
channel and use them to override the (default) value in the database
for the channel (which is ACKT=YES), such that the operator does not
have to acknowledge transient alarms, as is the behaviour of alh
(version 1.2.2).
I understand that the way to do this is to run the alh with -caputackt
cmd line option. The expected behaviour is that alh will set all
channels' ACKT filed to NO where it finds a 'T' set in the alh config
file.
To be clear, the command line I am using to start the alh is:
alh -global -caputackt -aCM -oCM -m 10000 alhConfigFile
Doing this, I get write access errors (i.e. alh process is not allowed
to write this field of the channel/record. Specifically, with R3.13.2, I get:
alCaPutGblAckT: ca_put acknowledge transients failed for PV <myPvName>
Return Status: Write access denied
Sorry to be so verbose but there is a recent tech-talk entry from
14aug2002 related to this...
On Wed, 14 Aug 2002, Marty Kraimer wrote:
> john sinclair wrote:
> > Can the ACKS and ACKT fields be modified via
> > channel access? When I try, ca_put fails.
> ACKS can only be changed via a DBR_PUT_ACKS request.
> ACKT can only be changed via a DBR_PUT_ACKT request.
> ACKS,ACKT are present for alarm handlers not general purpose CA clients.
> Note that access security can be used to limit who/where/when can modify these
> fields.
> Marty Kraimer
I am not sure how to accomplish Marty's suggestion. How do I get the
alh to use "a DBR_PUT_ACKT request"? Do I need another version of libca.so?
I saw no change using R3.13.6 and have not yet tried with R3.14.
thanks for any help,
Dayle
- Re: Getting Alarm Handler (1.2.9 or 1.2.10) to write to ACKT field Ralph . Lange
RE: FILETIME to epicsTimeStamp Jeff Hill
medm/dm2k executable for Windoze Rarback, Harvey
<2002>
TDS300 driver maintainer? Eric Norum
<2002>
