1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: S_errno_EINVAL
To: "'Pedro Gigoux'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Cc: "Jeff Hill" <[email protected]>
Date: Thu, 29 Aug 2002 16:36:21 -0600
Pedro,
> CAC: Unable to connect port 5064 on "10.2.2.106:5064"
> because 22="S_errno_EINVAL"
> dbCa:exceptionCallback stat Network connection lost channel unknown
This looks like a benign glitch in EPICS R3.13. It appears that one
thread called the connect() system call briefly after another thread
closed the socket.
Your observation that a hard reboot fixed the problem, and a soft reboot
did not, does not immediately point to a software problem.
Have you seen this situation occur more than once? Which version of
EPICS was running?
Jeff
--- Begin Message ---
Subject: S_errno_EINVAL
To: "EPICS Tech-Talk" <[email protected]>
Date: Wed, 28 Aug 2002 11:57:56 -0600
Title: S_errno_EINVAL
Can someone tell me what the following error message means:
CAC: Unable to connect port 5064 on "10.2.2.106:5064" because
22="S_errno_EINVAL"
10.2.2.106 is the IP of another crate where the system is supposed to
get a value. The system did not work properly when rebooted with a
CTRL-X, but it started to work fine after a hard reset.
Pedro.
--- End Message ---
S_errno_EINVAL Pedro Gigoux
Prev: RE: FILETIME to epicsTimeStamp Jeff Hill
Next: pprsyd library and header files for cau? Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: S_errno_EINVAL Pedro Gigoux
