What a coincidence!!!
We have also just ordered some DIN-mount PC (PC/104 form factor) from Kontron (formerly PEP modular) and have an arrangement to look at their driver software. I believe the Profibus hardware is based on the Siemens ASPC2 chip. We are hoping to run Linux.
In discussion with SST, it appears that they also have a similar offering and a development kit for Linux. I've heard that before though, and it turned out to be the source code to the DOS driver, but it's worth a closer look to speed up development.
When you start to put together your team, let me know how I can contribute. Feel free to contact me directly.
Robby Tanner
Canadian Light Source
University of Saskatchewan
101 Perimeter Road
Saskatoon, Saskatchewan
Canada
S7N 0X4
Ph: (306) 657-3582
Fax: (306) 657-3535
http://www.lightsource.ca
> -----Original Message-----
> From: Matthias Clausen [mailto:[email protected]]
> Sent: Friday, August 23, 2002 7:16 AM
> To: Robby Tanner
> Cc: Steve Hunt; EPICS tech-talk
> Subject: Re: Siemens/Profibus Drivers
> Hi Robby,
> we are using several S7 at DESY connected to EPICS through Ethernet.
> The development is based on the code which we've copied from
> PSI under their license agreement.
> Elder Matias also contacted us for our modified version. He
> could not reach Steve Hunt to get an approval.
> Steve??
> So we are stuck here.
> But if you are going towards Profibus-DP we could work together.
> We have a development for Profibus-DP in the pipe. The time
> frame is end of this year. We will use Softing Profibus
> boards with the PC104 form factor. They will be installed in
> DIN Rail PC's running vxWorks. This task just started and I
> have not jet a clear information how much time we (Slava
> Korobov) will need to get it running.
> Take care
> Matthias
> p.s. We will start from the Softing DOS drivers.
> Robby Tanner wrote:
> > Hello all,
> > We have a variety of Siemens S7-300 and S7-400 PLCs that we
> need to integrate in to EPICS. I'm wondering if anyone has
> any information on where to begin. Ideally, we would like to
> talk S7 to them but failing that could probably settle for
> Profibus-DP. From the IOC side of things, we have a Siemens
> PCI card CP-5613 for communicating with the PLCs.
> > As you might have guessed, I'm new to researching
> EPICS-type info. and somewhat green with Profibus in general.
> > Any pointers, comments or suggestions greatly appreciated.
> > Regards,
> > Robby Tanner B.Sc. (EE), B.Sc. (Cmpt. Sci)
> > Controls Engineer
> > 101 Perimeter Road
> > Canada
> > S7N 0X4
> > Ph: (306) 657-3582
> > Fax: (306) 657-3535
Re: Siemens/Profibus Drivers Matthias Clausen
RE: Siemens/Profibus Drivers Robby Tanner
<2002>
<2002>
