1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: HP Lan-GPIB gateway
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Thu, 22 Aug 2002 07:31:38 -0500
Eric,
 The two values I seem to have access to via telnet to the gateway are:
Lan Timeout : 10 (seconds)
IO-Timoute  : 120 (seconds)
Eric Norum wrote:
> On Wednesday, August 21, 2002, at 11:53 AM, [email protected] wrote:
> > I am using the HP (Agilent) E2050A Lan /GPIB gateway with Epics 3.14b2.
> > I have some device support for a scope which I've modified from pre
> > 3.14 - and it's running on a solaris IOC. If I leave the device (the
> > gateway) unaddressed for a 'long' period of time (~30 minutes) and then
> > send a command to a GPIB instrument, I receive the following message:
> > hpWriteCmd(142f28, 1320b4, 1): RPC: Unable to receive; An event
> > requires attention
> > At this point, the only way to re-establish communications is to
> > "reboot" the ioc.
> > Any ideas here?
> What values do you have the 2050A communication timeouts set to?
> Department of Electrical Engineering
> University of Saskatchewan
> Saskatoon, Canada.
> Phone: (306) 966-5394   FAX:   (306) 966-5407
| S. Joshua Stein                         |
| Electronics Engineer                    |
| Accelerator Systems Division            |
| Advanced Photon Source                  |
| Argonne National Laboratory             |
| www.aps.anl.gov/asd/people/stein/htdocs |
Re: HP Lan-GPIB gateway Eric Norum
Prev: Re: HP Lan-GPIB gateway Eric Norum
Next: Re: Siemens/Profibus Drivers Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: timestamp question Kevin Tsubota
