1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Macro names
To: "'Andrew Johnson '" <[email protected]>, "'EPICS tech-talk '" <[email protected]>
Date: Fri, 16 Aug 2002 12:41:03 -0700
I do not do anything exotic with my macros, but I would like to.
Specifically, I have two closely related databases called conb and simb in
which conb provides control functions and simb is a simulator for the
hardware that conb would normally control.  Naturally, the structures of the
two databases are very closely related, so that every hardware interface in
conb, say conb:a:b:c, has a corresponding simulation, simb:a:b:c.
The current macros allow me to parse the heirarchical container,
   $H = conb:a:b,
and the record name,
   $I = c.
For my purpose I would like to parse out different levels of the record
name, perhaps with a syntax like $B(n) that would pick out everything before
the n'th occurance of the separator, and $A(n) that would pick out
everything after the n'th separator.  I would get the desired record name in
the simulator from a record name in the controller with a macro of the form
   "simb:$A(1)".
I can think of places in my databases that I would like to use the more
general syntax I have suggested, but for me this would be the most useful
application.
Just a thought that you might consider for the wish list.
Cheers,
Russell O. Redman
-----Original Message-----
To: EPICS tech-talk
Sent: 8/15/02 12:57 PM
Subject: Macro names
A couple of questions about macro substitution in database files that I
need to check before I define some changes that could adversely affect
some EPICS sites:
1. Does anybody currently use macro names that have funny characters in
them?  The EPICS macro library allows almost any character to be used in
a
name right now, but I'm thinking of significantly restricting this in
R3.15 (and within VDCT) to allow only alpha-numerics and underscore
[a-zA-Z0-9_] characters in the macro name.  Macro values will obviously
still be able to contain any character.  Any complaints, or requests for
additional characters to be added to that list?
2. Does anybody actually use the facility whereby macro names can
themselves be constructed using macros? - eg $(xx$(y)_$(zz))  I'm not
threatening to change this, just interested to hear if it's actually
useful.
I'm in the process of defining how hierarchical templates should work
for
VDCT, and I need to add some syntax to macro names so templates can be
usefully modular.
- Andrew
Edsger W. Dijkstra, 1930-2002: "The use of COBOL cripples the mind;
its teaching should, therefore, be regarded as a criminal offence."
Prev: EPICS BASE 3.14.0beta2 Application Developer's Guide Marty Kraimer
Next: Re: Macro names Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Macro names Peregrine M. McGehee
Next: EPICS BASE 3.14.0beta2 Application Developer's Guide Marty Kraimer
