Hi All, I'm trying to get the R3.14.0beta2 release example loading but get the following errors during the iocInit. I'm using solaris-sparc-gnu host. The calc record type all seem to load fine. Can someone please point me in the right direction? I've attached by output example.dbd and xxRecord.dbd files. Thank you Kevin kamaole:iocexample> ../../bin/solaris-sparc-gnu/example st.cmd Starting iocInit ############################################################################ ### @(#)EPICS IOC CORE built on Jul 15 2002 ### @(#)Version R3.14.0.beta.1 $R3-14-0-beta-1$ $2001/09/13 19:13:12$ ############################################################################ filename="../recGbl.c" line number=114 Missing device support entry table PV: ktsubotaHost:aiExample ai: init_record filename="../recGbl.c" line number=114 Missing device support entry table PV: ktsubotaHost:aiExample1 ai: init_record filename="../recGbl.c" line number=114 Missing device support entry table PV: ktsubotaHost:aiExample2 ai: init_record filename="../recGbl.c" line number=114 Missing device support entry table PV: ktsubotaHost:aiExample3 ai: init_record ktsubotaHost:subExample mySubInit process 29898 filename="../recGbl.c" line number=114 Missing device support entry table PV: ktsubotaHost:xxxExample xxx: init_record iocInit: All initialization complete epics> epics> epics> dbpr ktsubotaHost:aiExample1,4 ACKS: <nil> ACKT: YES ADEL: 0 ALST: 0 AOFF: 0 ASG: ASLO: 1 ASP: 0x000b8b98 BKPT: 0x00 DESC: Analog input No. 1 DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 27216 DPVT: 0x00000000 DSET: 0x00000000 DTYP: <nil> EGU: Counts EGUF: 10 EGUL: 0 EOFF: 0 ESLO: 1 EVNT: 0 FLNK:CONSTANT 0 HHSV: MAJOR HIGH: 6 HIHI: 8 HOPR: 10 HSV: MINOR HYST: 0 INIT: 0 INP:DB_LINK ktsubotaHost:calcExample1.VAL NPP NMS LALM: 0 LBRK: 0 LCNT: 0 LINR: NO CONVERSION LLSV: MAJOR LOLO: 2 LOPR: 0 LOW: 4 LSET: 0x00000000 LSV: MINOR MDEL: 0 MLIS: 0x000000000000000000000000 MLOK: 0x00000000 MLST: 0 NAME: ktsubotaHost:aiExample1 NSEV: INVALID NSTA: <nil> ORAW: 0 PACT: 5 PBRK: 0x00000000 PHAS: 0 PINI: NO PPN: 0x00000000 PPNR: 0x00000000 PREC: 0 PRIO: LOW PROC: 0 PUTF: 10 RDES: 0x00000000 ROFF: 0 RPRO: 152 RSET: 0x00000000 RVAL: 0 SCAN: Passive SDIS:CONSTANT SEVR: INVALID SIML:CONSTANT SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT SMOO: 0 SPVT: 0x00000000 STAT: UDF SVAL: 0 TIME: 0x0000000000000000 TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 1 VAL: 0 epics> epics> dbl ktsubotaHost:aiExample ktsubotaHost:aiExample1 ktsubotaHost:aiExample2 ktsubotaHost:aiExample3 ktsubotaHost:calcExample ktsubotaHost:calcExample1 ktsubotaHost:calcExample2 ktsubotaHost:calcExample3 ktsubotaHost:subExample ktsubotaHost:xxxExample epics> Attachment:
example.dbd Attachment:
xxxRecord.dbd
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
