1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How do I use registryFunctionAdd
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Tue, 30 Jul 2002 11:52:55 -0600
Thanks, Marty
With a little help from Jeff on C++,
(I needed to surround the genSubUtil.h header file with
#ifdef __cpluplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
to keep c++ from mangling the subroutine names.
my genSub record is now working.
Rozelle
At 08:22 AM 7/30/2002 -0500, Marty Kraimer wrote:
I am attaching an example that works for subRecord.
The Makefile will just contain one extra statement similar to
example_SRCS += dbSubExample.cpp
Please note that the example works because constructors for static C++ objects get called when a application starts (on vxWorks when ld command is executed). The end of the example has the statements:
 * Register commands on application startup
class mySubRegister {
  public:
    mySubRegister() { mySubRecordFunctionsRegister(); }
static mySubRegister mySubRegisterObj;
mySubRegisterObj is a static object. At application startup its constructor is executed. In this example the constructor just calls mySubRecordFunctionsRegister.
Marty Kraimer
Rozelle Wright wrote:
> I am attempting to make a genSub record work with EPICS 3.14.beta1 using an
> example application and iocsh running on a pc with WINDOWS XP.  I see that
> registry information is automatically generated for the record, device and
> driver support from the dbd file, but I don't know how to persuade iocinit
> to find the functions that I need for the initialization and processing of
> the subroutine record.
> The genSubRecord code calls  registryFunctionFind to retrieve the address
> of the function from the name in the record (and fails because the
> functions are not registered).
> According to the registry section of the application developers guide, I
> should be using registryFunctionAdd to register the function, but I am not
> sure where to put this call.
> Has anyone done this who could give me an example?
> Thanks for any help you can give me.
> Rozelle Wright
> [email protected]#include <stddef.h>
#include <stdlib.h>
#include <stdarg.h>
#include <stdio.h>
#include <string.h>
#include <registryFunction.h>
#include <subRecord.h>
extern "C" {
typedef long (*processMethod)(subRecord *precord);
long mySubInit(subRecord *precord,processMethod process);
long mySubProcess(subRecord *precord);
void mySubRecordFunctionsRegister(void);
    printf("%s mySubInit process %p\n",precord->name,process);
    return(0);
    printf("%s mySubProcess\n",precord->name);
    return(0);
if(!registryFunctionAdd("mySubInit",(REGISTRYFUNCTION)mySubInit))
errlogPrintf("mySubRecordFunctionsRegister registryFunctionAdd failed\n");
if(!registryFunctionAdd("mySubProcess",(REGISTRYFUNCTION)mySubProcess))
  public:
How do I use registryFunctionAdd Rozelle Wright
Re: How do I use registryFunctionAdd Marty Kraimer
Prev: Re: side-effect of malloc() in startup file Korhonen Timo
Next: GPIB + vxStats hangs IOC Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: How do I use registryFunctionAdd Marty Kraimer
