Hi Peregrine,
Peregrine M. McGehee wrote:
The vxWorks tShell crashes after calls to both malloc() and
iocInit within a st.cmd have been traced to the drvTS.c TSinit()
routine that is called within iocInit. The environment is
Power PC; VxWorks 5.4; EPICS R3.13.5 and requires definition
of local synchronized timestamp support routines
(http://www.aps.anl.gov/asd/controls/hideos/GTS.html).
This is a consequence of insufficient (none!) range checking for
access within the TSdata.event_table array of struct timespec
allocated in TSinit(). The quick patch is to always have an
ErSyncEvent() function that returns an event number less than
the return value of ErHaveReceiver() when supplying local
timestamp support. The harder correction is to rewrite drvTS!
....which is underway. I hope to fix some other problems, too.
The progress has not been as fast as I had hoped (busy with other
things) but the first rewrites (that can be published) should be ready
within a month or two.
best regards,
Timo
Timo Korhonen PSI (Paul Scherrer Institut)
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3151
e-mail:
[email protected]
- side-effect of malloc() in startup file Peregrine M. McGehee
- Re: side-effect of malloc() in startup file Peregrine M. McGehee
Re: How do I use registryFunctionAdd Rozelle Wright
<2002>
seq-1.9.6-beta redux Laznovsky, Michael
<2002>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
