Dear Sir,
I have encounted a problem of recording channels while using ChannelArchive(version 1.7.1).
QDR1:INT-AVG ; QDR1:X-AVG ; QDR1:Y-AVG are three ai record, they all scanned at a period of 1 second.And I can use MEDM to monitor these channels,it's working well.
While I try to use channelArchiver to record these channel, it seems there have some problems. I have tried to use different config files, but none of them worked. Here is what I have done:
1. step 1.
edit the epics.cfg file ,including these lines to archive 3 channels.
QDR1:INT-AVG
QDR1:X-AVG
QDR1:Y-AVG
then start to record the channels using command:
$ArchiveEngine epics.cfg dbpm_data_dir
and I can view and config the channels http://localhost:4812/
Waiting for several minutes, using http://localhost:4812/stop to end the
archiver
Using ArchiveExport to export the archived dbpm_data_dir:
$ArchiveExport -text -output dbpm_data dbpm_data_dir
the contents of dbpm_data is like this:
Time QDR1:INT-AVG [digits] Status QDR1:X-AVG [mm] Status QDR1:Y-AVG [mm] Status
7/24/2002 11:05:11.024723023 5073 0.0286811 0.00344885
7/24/2002 11:05:12.000000000 5073 0.0286811 0.00344885
7/24/2002 11:05:13.000000000 5073 0.0286811 0.00344885
7/24/2002 11:05:14.000000000 5073 0.0286811 0.00344885
7/24/2002 11:05:15.000000000 5073 0.0286811 0.00344885
7/24/2002 11:05:16.000000000 5073 0.0286811 0.00344885
7/24/2002 11:05:17.000000000 5073 0.0286811 0.00344885
The value of these three channels never changed?
2. step 2.
change epics.cfg to :
QDR1:INT-AVG 1 Monitor
QDR1:X-AVG 1 Monitor
QDR1:Y-AVG 1 Monitor
follow the operation as in step 1.
The exported dbpm_data:
7/24/2002 11:15:04.014441653 5071 0.0286927 0.00266235
no matter how long lasted, there have only one line in the file.
3. step 3.
Using 5 seconds scan in epics.cfg:
QDR1:INT-AVG 5
QDR1:X-AVG 5
QDR1:Y-AVG 5
And now the contents of dbpm_data is :
7/24/2002 11:18:53.011652405 5072 0.0284897 0.00256317
7/24/2002 11:18:55.000000000 5072 0.0284897 0.00256317
7/24/2002 11:19:00.000000000 5072 0.0284897 0.00256317
7/24/2002 11:19:05.000000000 5072 0.0284897 0.00256317
7/24/2002 11:19:10.000000000 5072 0.0284897 0.00256317
7/24/2002 11:19:15.000000000 5072 0.0284897 0.00256317
7/24/2002 11:19:20.000000000 5072 0.0284897 0.00256317
It is similar to step1.
4. step 4.
Set epics.cfg to 5 seconds monitor:
QDR1:INT-AVG 5 Monitor
QDR1:X-AVG 5 Monitor
QDR1:Y-AVG 5 Monitor
the export dbpm_data is like this:
7/24/2002 11:22:27.007671187 5076 0.0291571 0.00354628
(Note:between different steps, I have deleted the old dbpm_data and dbpm_data_dir. so the new output file dbpm_data have no relationship with the old one)
We can see that the channel value changed in different steps, but it can't record the correct value for individual step. I don't know what's wrong with it, can you help me?
BTW: I can use ChannelArchive to record the example channel "$(USER):aiExample" or "$(USER):calcExample". it works very well while include these two channels. And also they scaned at a period of 1 second, so I really amazing about it.
Best Regards,
Cheng Weixing
P.O. Box 800-204,Shanghai, P.R.China 201800
Beam Instrumentation Group, SSRF
Email: [email protected]
Tel:(86-21)5955 3998-Ext449
- Re: Problem of ChannelArchive Thomas . Birke
Re: Matthieu Bec
<2002>
Re: Janet Anderson
<2002>
