1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA Proxy Gateway (performance tweak release 1.3.3)
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 19 Jul 2002 15:40:44 +0200
Hi all -
the 1.3.3 release of the CA Proxy Gateway is available. It is a
optimization release, i.e. there are no bug fixes and no changes in
functionality, configuration or user interface.
1.3.3 contains a fix in the Gateway code and an additional patch for the
base the Gateway is built against that _dramatically_ increase the
client-to-Gateway connection performance. (We have seen clients
connecting more than 5 times faster - even large panels or alarm
handlers with many channels now connect almost instantly.) Also the
Gateway-induced load on the DNS service has been reduced.
Another hint: The regexp library that you need for the Gateway is by
default compiled without optimization. Recompile it using CFLAGS=-O3 on
the make command line to get a smaller and faster library image, then
re-link the Gateway.
As always - download tars and install instructions can be found on the
Gateway's web page: http://www-csr.bessy.de/control/SoftDist/Gateway/
(It is still important to follow the instructions closely!)
People with access to the APS repository may check out the sources in
epics/extensions/src/gateway using the tag "Gateway1_3_3".
Happy connecting!
Ralph
Prev: seq-1.9.6-beta Laznovsky, Michael
Next: Re: genSub for EPICS 314? Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: How to set the correct IOC time Cheng Weixing@ssrc
