g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux
To: "David H. Thompson" <thompsondh@ornl.gov>
Cc: techtalk <tech-talk@aps.anl.gov>
Date: Fri, 12 Jul 2002 17:28:55 -0400
>>> On 7/10/2002 at 16:01:50 EDT, David H Thompson wrote:
  > This is for those who are interested in the gcc-2.7.2 cross compiler
  > from Wind River that I discussed at the Epics meeting.
I built gcc-2.7.2.3 from the standard source distribution (not WRS), with
this configuration:
../configure --target=m68k-wrs-vxworks --prefix=/usr/local/vx/v53/host/Linux -program-prefix= -program-suffix=68k --with-gnu-as --with-gnu-ld --with-headers=/usr/local/vx/v53/target/h --with-libs=/usr/local/vx/v53/target/lib
echo host=i686-unknown-linux target=m68k-wrs-vxworks build=i686-unknown-linux
I have been using this on Redhat 7.0 to build EPICS 3.13.[1,2,4] for mv167
and mv177 targets loading vxWorks V5.3 kernels built with the official
Tornado 1.0 tools on Solaris.  I have had no problems.
I tried gcc-2.8.1 first, which produced code which would load, but not
execute.
I have not tried this with other target architectures, and the only C++
code built is what's in 3.13 base.
Did you try the standard gcc-2.7.2.3 ?
Did WRS make further changes which are needed for PPC, EPICS 3.14 or
vxWorks 5.4 ?
Brian McAllister                    Controls Programmer/Beam Physicist
mcallister@mit.edu                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Prev: Re: iocsh under Epics r3.14 RTEMS Eric Norum
Next: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Cross compiler source and patch file for gcc-2.7.2 on Linux David H. Thompson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
