Finally some RTEMS posting :-) Bill Nolan wrote: Hi all, I've come to an interesting impass in trying to get the example IOC to start I slightly patched rtems_init.c so it calls main(). Note that the appended patch also contains some other (small but important) fixes and workarounds useful under RTEMS - some things have already been fixed, I had been told, but probably are not in the distributed beta1 release yet. What CPU/BSP are you using? Regards -- Till
Index: RTEMS/base/rtems_init.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/RTEMS/base/rtems_init.c,v retrieving revision 1.1.1.1 diff -c -r1.1.1.1 rtems_init.c *** rtems_init.c 2002/03/09 18:09:24 1.1.1.1 --- rtems_init.c 2002/07/11 01:00:13 *************** *** 193,204 **** --- 193,213 ---- &rtems_bsdnet_config }; + #define DO_NORMAL_MAIN + /* * RTEMS Startup task */ rtems_task Init (rtems_task_argument ignored) { + #ifndef DO_NORMAL_MAIN + /* T. Straumann: invoke global constructors + * from a task context... + */ + extern void __do_global_ctors(void); + __do_global_ctors(); + #endif /* * Create a reasonable environment */ *************** *** 207,224 **** putenv ("IOCSH_PS1=epics> "); putenv ("IOCSH_HISTSIZE=20"); /* * Start network */ printf ("***** Initializing network *****\n"); rtems_bsdnet_initialize_network (); printf ("***** Initializing TFTP *****\n"); rtems_bsdnet_initialize_tftp_filesystem (); for (;;) { printf ("***** Initializing NTP *****\n"); if (rtems_bsdnet_synchronize_ntp (0, 0) >= 0) break; ! epicsThreadSleep (10.0); } printf ("***** Initializing syslog *****\n"); openlog ("IOC", LOG_CONS, LOG_DAEMON); --- 216,239 ---- putenv ("IOCSH_PS1=epics> "); putenv ("IOCSH_HISTSIZE=20"); + /* T. Straumann: epicsThreadSleep() doesnt work before clockInit() */ + clockInit(); + /* * Start network */ + printf ("\nWelcome to EPICS on RTEMS\n"); printf ("***** Initializing network *****\n"); rtems_bsdnet_initialize_network (); printf ("***** Initializing TFTP *****\n"); rtems_bsdnet_initialize_tftp_filesystem (); for (;;) { + double sl=10.0; printf ("***** Initializing NTP *****\n"); if (rtems_bsdnet_synchronize_ntp (0, 0) >= 0) break; ! printf("SLEEP %g\n",sl); ! epicsThreadSleep (sl); } printf ("***** Initializing syslog *****\n"); openlog ("IOC", LOG_CONS, LOG_DAEMON); *************** *** 230,235 **** --- 245,251 ---- printf ("***** Executing EPICS startup script *****\n"); iocshRegisterRTEMS (); rtems_set_directory (); + #if 0 iocsh ("st.cmd"); /* *************** *** 237,242 **** --- 253,272 ---- */ epicsThreadSleep (2.0); iocsh (NULL); + #else + #ifdef DO_NORMAL_MAIN + { + char *args[]={"iocsh","st.cmd"}; + main(2,args); + } + #else + { + extern int rtems_main(int, char **); + char *args[]={"iocsh","st.cmd"}; + rtems_main(2,args); + } + #endif + #endif LogFatal ("Console command interpreter terminated"); } Index: RTEMS/base/rtems_netconfig.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/RTEMS/base/rtems_netconfig.c,v retrieving revision 1.1.1.1 retrieving revision 1.2 diff -c -r1.1.1.1 -r1.2 *** rtems_netconfig.c 2002/03/09 18:09:24 1.1.1.1 --- rtems_netconfig.c 2002/03/09 19:08:38 1.2 *************** *** 44,49 **** --- 44,52 ---- #else /* Use NIC provided by BSP */ # define NIC_NAME RTEMS_BSP_NETWORK_DRIVER_NAME # define NIC_ATTACH RTEMS_BSP_NETWORK_DRIVER_ATTACH + /* T. Straumann, TSILL, 12/18/2001, added declaration, just in case */ + extern int + RTEMS_BSP_NETWORK_DRIVER_ATTACH(); #endif static struct rtems_bsdnet_ifconfig netdriver_config = { Index: libCom/cxxTemplates/tsFreeList.h =================================================================== RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/cxxTemplates/tsFreeList.h,v retrieving revision 1.1.1.1 retrieving revision 1.2 diff -c -r1.1.1.1 -r1.2 *** tsFreeList.h 2002/03/09 18:09:30 1.1.1.1 --- tsFreeList.h 2002/04/05 00:52:34 1.2 *************** *** 74,81 **** template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u > struct tsFreeListChunk { ! tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext; tsFreeListItem < T, DEBUG_LEVEL > items [N]; }; template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u > --- 74,84 ---- template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u > struct tsFreeListChunk { ! /* Till Straumann <[email protected]>, 2002/4/4 ! * put the items first to maintain alignment. ! */ tsFreeListItem < T, DEBUG_LEVEL > items [N]; + tsFreeListChunk < T, N, DEBUG_LEVEL > *pNext; }; template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u > Index: libCom/osi/os/RTEMS/osdPoolStatus.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/osi/os/RTEMS/osdPoolStatus.c,v retrieving revision 1.1.1.1 retrieving revision 1.2 diff -c -r1.1.1.1 -r1.2 *** osdPoolStatus.c 2002/03/09 18:09:31 1.1.1.1 --- osdPoolStatus.c 2002/03/09 18:38:31 1.2 *************** *** 8,12 **** --- 8,17 ---- */ epicsShareFunc int epicsShareAPI osiSufficentSpaceInPool () { + /* T. Straumann: 2/12/2002 the current RTEMS implementation + of this has a serious flaw (killing + real-time responsiveness!!!) DONT USE return (malloc_free_space() > 100000); + */ + return 1; } Index: libCom/osi/os/RTEMS/osdThread.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/epics/base/src/libCom/osi/os/RTEMS/osdThread.c,v retrieving revision 1.1.1.1 retrieving revision 1.2 diff -c -r1.1.1.1 -r1.2 *** osdThread.c 2002/03/09 18:09:31 1.1.1.1 --- osdThread.c 2002/03/09 18:52:38 1.2 *************** *** 118,131 **** unsigned int epicsThreadGetStackSize (epicsThreadStackSizeClass size) { switch(size) { ! case epicsThreadStackSmall: return( 4000*ARCH_STACK_FACTOR); ! case epicsThreadStackMedium: return( 6000*ARCH_STACK_FACTOR); ! case epicsThreadStackBig: return(11000*ARCH_STACK_FACTOR); default: errlogPrintf("epicsThreadGetStackSize illegal argument"); } ! return(11000*ARCH_STACK_FACTOR); } /* --- 118,136 ---- unsigned int epicsThreadGetStackSize (epicsThreadStackSizeClass size) { + unsigned int rval=(11000*ARCH_STACK_FACTOR); + /* T. Straumann: make sure we allocate at least RTEMS_MINIMUM_STACK_SIZE */ switch(size) { ! case epicsThreadStackSmall: rval = ( 4000*ARCH_STACK_FACTOR); break; ! case epicsThreadStackMedium: rval = ( 6000*ARCH_STACK_FACTOR); ! case epicsThreadStackBig: break; default: errlogPrintf("epicsThreadGetStackSize illegal argument"); + break; } ! if (rval < RTEMS_MINIMUM_STACK_SIZE) ! rval = RTEMS_MINIMUM_STACK_SIZE; ! return rval; } /* *************** *** 261,267 **** if (!initialized) epicsThreadInit(); if (stackSize < RTEMS_MINIMUM_STACK_SIZE) { errlogPrintf ("epicsThreadCreate %s illegal stackSize %d\n",name,stackSize); ! return 0; } strncpy (c, name, sizeof c); sc = rtems_task_create (rtems_build_name (c[0], c[1], c[2], c[3]), --- 266,274 ---- if (!initialized) epicsThreadInit(); if (stackSize < RTEMS_MINIMUM_STACK_SIZE) { errlogPrintf ("epicsThreadCreate %s illegal stackSize %d\n",name,stackSize); ! /* T. Straumann: just increase the stack size */ ! /* return 0; */ ! stackSize=RTEMS_MINIMUM_STACK_SIZE; } strncpy (c, name, sizeof c); sc = rtems_task_create (rtems_build_name (c[0], c[1], c[2], c[3]),
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
