1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: tnetDrv behavior
To: [email protected]
Date: Fri, 05 Jul 2002 15:20:18 -0600
In tracking down an apparent channel access failure, we
discovered that the terminal server driver (tnetDrv) behaves
badly when the addressed terminal server port is logged out.
Specifically, the combination of the default high priority
(3) of the tTnet task coupled with the lack of a timeout
argument in the following causes the IOC to lock up.
  if (select (FD_SETSIZE, &readFds, NULL, NULL, NULL) == ERROR)
            logMsg ("tnetDev: ERROR--select 0x%x\n",
                getErrno, NULL, NULL, NULL, NULL, NULL);
            break;
Deletion of the tTnet task restored both channel access and
telnet communications.
We will add a default timeout argument to this select call - unless
other tnetDrv users have already done so.
- Peregrine
Peregrine M. McGehee		(505) 437-6822
Sloan Digital Sky Survey	Apache Point Observatory
Prev: Re: GreenSpring memory Andrew Johnson
Next: Re: waveform calculations Alexei Dmitrovski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: waveform calculations Alexei Dmitrovski
Next: 3.14 vs g++ Jim Thomas
