1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: ezca monitor trouble
To: "'[email protected]'" <[email protected]>
Cc: "Miller, Edward S." <[email protected]>
Date: Wed, 26 Jun 2002 17:57:23 -0700
To anybody who uses EZCA (EZ Channel Access) Monitors:
During testing of a new CA client that uses EZCA for monitors,
we came across a unique (rare) problem:
(1) While the client was stuck in ezcaDelay (1 sec timeout),
    a new value came in for a PV right before the IOC was rebooted.
(2) When the client then called ezcaNewMonitorValue, it was told
    a new value was available (the needs-reading flag was set for
    that PV).
(3) The client then called ezcaGetWithStatus and was NOT
    given the new value and was told (via error return) that the
    channel was disconnected.
(4) After the next ezcaDelay, the ezcaNewMonitorValue still
    returned TRUE so the client again called ezcaGetWithStatus
    and got the same error (and did this over and over again,
    logging each failure at the 1 second rate until the reboot
    finished).
Perhaps using EZCA monitors is not a good idea.  In any case,
I would like to change ezca.c in one of three ways, (1) being
my preference:
(1) For monitors only, if the needs-reading flag is set,
    the various EZCA get routines return the available value
    without checking for channel disconnect and then
    reset the needs-reading flag.  Next time the error is
    returned.
OR
(2) The various EZCA get routines reset the needs-reading
    flag if the channel is disconnected and the last value
    is lost.
OR
(3) ezcaNewMonitorValue returns FALSE if the channel is
    disconnected and the last value is lost.
Comments/other suggestions?  Thanks very much,
Stephanie Allison ([email protected])
Prev: Duke Storage Ring Re-Commissioned Steven Hartman
Next: GreenSpring memory John Faucett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
