1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [Q] How to set a timestamp in a device support routine.
To: [email protected]
Date: Tue, 25 Jun 2002 09:26:33 -0400
Marty:
Carl and I believe that you meant that the tse values that protect the
record's time stamp from being set by the time system should be:
epicsTimeEventDeviceTime (via device support) and
epicsTimeEventLinkPropagate(for flinks).
I take it now that there are three reserved values that this means that new
device support routines that could set the time stamp would have to check
for tse==epicsTimeEventDeviceTime  before setting the time stamp.
> Dont forget that recGblGetTimeStamp will have to be changed to
>void epicsShareAPI recGblGetTimeStamp(void* prec)
>      struct dbCommon* pr = (struct dbCommon*)prec;
>      int status = 0;
>      if(pr->tsel.type!=CONSTANT)
>          dbGetLink(&(pr->tsel), DBR_SHORT,&(pr->tse),0,0);
>      if (pr->tse!=epicsTimeEventBestTime &&
> pr->tse!=epicsTimeEventDeviceTime )
>          status = epicsTimeGetEvent(&pr->time,(unsigned)pr->tse);
>      if(status) errlogPrintf("%s recGblGetTimeStamp failed\n",pr->name);
> Unless I hear objections I will make these changes to 3.13 and 3.14.
> Marty
Re: [Q] How to set a timestamp in a device support routine. Marty Kraimer
Prev: Re: [Q] How to set a timestamp in a device support routine. Marty Kraimer
Next: Diff between Torando 2.1 and 2.2 Luchini, Kristi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: [Report] EPICS R3.13.6 build on RH Linux7.3 Noboru Yamamoto
