1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: genSub & PPC crash in dbProcess?
To: <[email protected]>
Date: Mon, 24 Jun 2002 17:48:26 -0600
Hello:
We are running into a strange problem with the genSub record.
It seems to work fine on several architectures,
but on R3.13.5, Tornado 2 with
cygnus-2.7.2-960126 egcs-971225 t202/SNS
(Linux->PPC cross compiler from WRS sources
 built for SNS) this is the problem.
dbProcess crashes when trying to process
the genSub record:
-> dbpf "cubicSpline.PROC", "1"
data access
Exception current instruction address: 0x01a4a538
Machine Status Register: 0x0000b030
Data Access Register: 0xc655a839
Condition Register: 0x48400022
Data storage interrupt Register: 0x0000b030
18c898 vxTaskEntry    +60 : shell ()
169998 shell          +18c: 1699c4 ()
169be8 shell          +3dc: execute ()
169d6c execute        +d8 : yyparse ()
1b1db8 yyparse        +7a8: 1afd00 ()
1afe78 yystart        +8f8: dbpf ()
1a39cb4 dbpf           +f8 : dbPutField ()
1a25e04 dbPutField     +458: dbProcess ()
1a319b4 dbNotifyCompletion+2c : ellDelete ()
The genSub's INAM init routine is called fine (it's just a printf),
the genSub's SADR points to the correct routine that's specified in SNAM,
calling the SNAM routine from the shell works
(again another printf).
It really seems to go wrong in the dbProcess call which
then never actually calls the genSub's SNAM routine.
Regards
Martin
Here are the details of the record, the debug messages
from the record when compiled with DEBUG defined,
a "dbpr" before the "dbpf ...PROC":
record(genSub, "cubicSpline")
        field(INAM, "cubicSplineInit")
        field(SNAM, "cubicSplineProcess")
        field(EFLG, "ON CHANGE")
        field(INPA, "10.0")
        field(FTA,  "DOUBLE")
        field(NOA,  "1")
###  @(#)Version R3.13.5 $2001/09/18 18:11:11$
Starting iocInit
Link(A): Address = 0x1b2cb10, Bytes = 8
Link(B): Address = 0x1b2cae0, Bytes = 40
Link(C): Address = 0x1b2cab0, Bytes = 40
Link(D): Address = 0x1b2ca80, Bytes = 40
Link(E): Address = 0x1b2ca50, Bytes = 40
Link(F): Address = 0x1b2ca20, Bytes = 40
Link(G): Address = 0x1b2c9f0, Bytes = 40
Link(H): Address = 0x1b2c9c0, Bytes = 40
Link(I): Address = 0x1b2c990, Bytes = 40
Link(J): Address = 0x1b2c960, Bytes = 40
Link(K): Address = 0x1b2c930, Bytes = 40
Link(L): Address = 0x1b2c900, Bytes = 40
Link(M): Address = 0x1b2c8d0, Bytes = 40
Link(N): Address = 0x1b2c8a0, Bytes = 40
Link(O): Address = 0x1b2c870, Bytes = 40
Link(P): Address = 0x1b2c840, Bytes = 40
Link(Q): Address = 0x1b2c810, Bytes = 40
Link(R): Address = 0x1b2c7e0, Bytes = 40
Link(S): Address = 0x1b2c7b0, Bytes = 40
Link(T): Address = 0x1b2c780, Bytes = 40
Link(U): Address = 0x1b2c750, Bytes = 40
Link(VALA): Address = 0x1b2c720, Bytes = 40
Link(VALB): Address = 0x1b2c6c0, Bytes = 40
Link(VALC): Address = 0x1b2c660, Bytes = 40
Link(VALD): Address = 0x1b2c600, Bytes = 40
Link(VALE): Address = 0x1b2c5a0, Bytes = 40
Link(VALF): Address = 0x1b2c540, Bytes = 40
Link(VALG): Address = 0x1b2c4e0, Bytes = 40
Link(VALH): Address = 0x1b2c480, Bytes = 40
Link(VALI): Address = 0x1b2c420, Bytes = 40
Link(VALJ): Address = 0x1b2c3c0, Bytes = 40
Link(VALK): Address = 0x1b2c360, Bytes = 40
Link(VALL): Address = 0x1b2c300, Bytes = 40
Link(VALM): Address = 0x1b2c2a0, Bytes = 40
Link(VALN): Address = 0x1b2c240, Bytes = 40
Link(VALO): Address = 0x1b2c1e0, Bytes = 40
Link(VALP): Address = 0x1b2c180, Bytes = 40
Link(VALQ): Address = 0x1b2c120, Bytes = 40
Link(VALR): Address = 0x1b2c0c0, Bytes = 40
Link(VALS): Address = 0x1b2c060, Bytes = 40
Link(VALT): Address = 0x1b2c000, Bytes = 40
Link(VALU): Address = 0x1b2bfa0, Bytes = 40
Input Link A is a CONSTANT
Input Link B is a CONSTANT
Input Link C is a CONSTANT
Input Link D is a CONSTANT
Input Link E is a CONSTANT
Input Link F is a CONSTANT
Input Link G is a CONSTANT
Input Link H is a CONSTANT
Input Link I is a CONSTANT
Input Link J is a CONSTANT
Input Link K is a CONSTANT
Input Link L is a CONSTANT
Input Link M is a CONSTANT
Input Link N is a CONSTANT
Input Link O is a CONSTANT
Input Link P is a CONSTANT
Input Link Q is a CONSTANT
Input Link R is a CONSTANT
Input Link S is a CONSTANT
Input Link T is a CONSTANT
Input Link U is a CONSTANT
Output Link VALA is a CONSTANT
Output Link VALB is a CONSTANT
Output Link VALC is a CONSTANT
Output Link VALD is a CONSTANT
Output Link VALE is a CONSTANT
Output Link VALF is a CONSTANT
Output Link VALG is a CONSTANT
Output Link VALH is a CONSTANT
Output Link VALI is a CONSTANT
Output Link VALJ is a CONSTANT
Output Link VALK is a CONSTANT
Output Link VALL is a CONSTANT
Output Link VALM is a CONSTANT
Output Link VALN is a CONSTANT
Output Link VALO is a CONSTANT
Output Link VALP is a CONSTANT
Output Link VALQ is a CONSTANT
Output Link VALR is a CONSTANT
Output Link VALS is a CONSTANT
Output Link VALT is a CONSTANT
Output Link VALU is a CONSTANT
cubicSplineInit was called
Calling symFindByNameEPICS from init_record
value = 0 = 0x0
dbpf "cubicSpline.TPRO", "1"
DBR_UCHAR:          1         0x1
value = 0 = 0x0
-> iocInit: All initialization complete
-> dbpr "cubicSpline", 4
A: 0x01b2cb10       ACKS: NO_ALARM      ACKT: (null)        ASG:
ASP: 0x00000000     B: 0x01b2cae0       BKPT: 0x00          BRSV: NO_ALARM
C: 0x01b2cab0       D: 0x01b2ca80       DESC:               DISA: 0
DISP: 0             DISS: (null)        DISV: 1             DPVT: 0x00000000
DSET: 0x00000000    DTYP: (null)        E: 0x01b2ca50       EFLG: ON CHANGE
EVNT: 0             F: 0x01b2ca20       FLNK:CONSTANT 0     FTA: DOUBLE
FTB: STRING         FTC: STRING         FTD: STRING         FTE: STRING
FTF: STRING         FTG: STRING         FTH: STRING         FTI: STRING
FTJ: STRING         FTK: STRING         FTL: STRING         FTM: STRING
FTN: STRING         FTO: STRING         FTP: STRING         FTQ: STRING
FTR: STRING         FTS: STRING         FTT: STRING         FTU: STRING
FTVA: STRING        FTVB: STRING        FTVC: STRING        FTVD: STRING
FTVE: STRING        FTVF: STRING        FTVG: STRING        FTVH: STRING
FTVI: STRING        FTVJ: STRING        FTVK: STRING        FTVL: STRING
FTVM: STRING        FTVN: STRING        FTVO: STRING        FTVP: STRING
FTVQ: STRING        FTVR: STRING        FTVS: STRING        FTVT: STRING
FTVU: STRING        G: 0x01b2c9f0       H: 0x01b2c9c0       I: 0x01b2c990
INAM: cubicSplineInit                   INPA:CONSTANT 10.0  INPB:CONSTANT
INPC:CONSTANT       INPD:CONSTANT       INPE:CONSTANT       INPF:CONSTANT
INPG:CONSTANT       INPH:CONSTANT       INPI:CONSTANT       INPJ:CONSTANT
INPK:CONSTANT       INPL:CONSTANT       INPM:CONSTANT       INPN:CONSTANT
INPO:CONSTANT       INPP:CONSTANT       INPQ:CONSTANT       INPR:CONSTANT
INPS:CONSTANT       INPT:CONSTANT       INPU:CONSTANT       J: 0x01b2c960
K: 0x01b2c930       L: 0x01b2c900       LCNT: 0             LFLG: IGNORE
LSET: 0x00000000    M: 0x01b2c8d0       MLIS: 0x000000000000000000000000
MLOK: 0x0000000000000000                N: 0x01b2c8a0       NAME:
cubicSpline
NOA: 1              NOB: 1              NOC: 1              NOD: 1
NOE: 1              NOF: 1              NOG: 1              NOH: 1
NOI: 1              NOJ: 1              NOK: 1              NOL: 1
NOM: 1              NON: 1              NOO: 1              NOP: 1
NOQ: 1              NOR: 1              NOS: 1              NOT: 1
NOU: 1              NOVA: 1             NOVB: 1             NOVC: 1
NOVD: 1             NOVE: 1             NOVF: 1             NOVG: 1
NOVH: 1             NOVI: 1             NOVJ: 1             NOVK: 1
NOVL: 1             NOVM: 1             NOVN: 1             NOVO: 1
NOVP: 1             NOVQ: 1             NOVR: 1             NOVS: 1
NOVT: 1             NOVU: 1             NSEV: NO_ALARM      NSTA: NO_ALARM
O: 0x01b2c870       ONAM:               OSAD: 0             OUTA:CONSTANT
OUTB:CONSTANT       OUTC:CONSTANT       OUTD:CONSTANT       OUTE:CONSTANT
OUTF:CONSTANT       OUTG:CONSTANT       OUTH:CONSTANT       OUTI:CONSTANT
OUTJ:CONSTANT       OUTK:CONSTANT       OUTL:CONSTANT       OUTM:CONSTANT
OUTN:CONSTANT       OUTO:CONSTANT       OUTP:CONSTANT       OUTQ:CONSTANT
OUTR:CONSTANT       OUTS:CONSTANT       OUTT:CONSTANT       OUTU:CONSTANT
OVAL: 0             OVLA: 0x01b2c6f0    OVLB: 0x01b2c690    OVLC: 0x01b2c630
OVLD: 0x01b2c5d0    OVLE: 0x01b2c570    OVLF: 0x01b2c510    OVLG: 0x01b2c4b0
OVLH: 0x01b2c450    OVLI: 0x01b2c3f0    OVLJ: 0x01b2c390    OVLK: 0x01b2c330
OVLL: 0x01b2c2d0    OVLM: 0x01b2c270    OVLN: 0x01b2c210    OVLO: 0x01b2c1b0
OVLP: 0x01b2c150    OVLQ: 0x01b2c0f0    OVLR: 0x01b2c090    OVLS: 0x01b2c030
OVLT: 0x01b2bfd0    OVLU: 0x01b2bf70    P: 0x01b2c840       PACT: 0
PHAS: 0             PINI: NO            PPN: 0x00000000     PPNN: 0x00000000
PREC: 0             PRIO: LOW           PROC: 0             PUTF: 0
Q: 0x01b2c810       R: 0x01b2c7e0       RDES: 0x00000000    RPRO: 0
RSET: 0x00000000    S: 0x01b2c7b0       SADR: 28123152      SCAN: Passive
SDIS:CONSTANT       SEVR: INVALID       SNAM: cubicSplineProcess
SPVT: 0x00000000    STAT: UDF           STYP: 0             SUBL:CONSTANT
T: 0x01b2c780       TIME: 0x0000000001b01e40                TOVA: 40
TOVB: 40            TOVC: 40            TOVD: 40            TOVE: 40
TOVF: 40            TOVG: 40            TOVH: 40            TOVI: 40
TOVJ: 40            TOVK: 40            TOVL: 40            TOVM: 40
TOVN: 40            TOVO: 40            TOVP: 40            TOVQ: 40
TOVR: 40            TOVS: 40            TOVT: 40            TOVU: 40
TPRO: 1             TSE: 0              TSEL:CONSTANT       U: 0x01b2c750
UDF: 1              UFA:                UFB:                UFC:
UFD:                UFE:                UFF:                UFG:
UFH:                UFI:                UFJ:                UFK:
UFL:                UFM:                UFN:                UFO:
UFP:                UFQ:                UFR:                UFS:
UFT:                UFU:                UFVA:               UFVB:
UFVC:               UFVD:               UFVE:               UFVF:
UFVG:               UFVH:               UFVI:               UFVJ:
UFVK:               UFVL:               UFVM:               UFVN:
UFVO:               UFVP:               UFVQ:               UFVR:
UFVS:               UFVT:               UFVU:               VAL: 0
VALA: 0x01b2c720    VALB: 0x01b2c6c0    VALC: 0x01b2c660    VALD: 0x01b2c600
VALE: 0x01b2c5a0    VALF: 0x01b2c540    VALG: 0x01b2c4e0    VALH: 0x01b2c480
VALI: 0x01b2c420    VALJ: 0x01b2c3c0    VALK: 0x01b2c360    VALL: 0x01b2c300
VALM: 0x01b2c2a0    VALN: 0x01b2c240    VALO: 0x01b2c1e0    VALP: 0x01b2c180
VALQ: 0x01b2c120    VALR: 0x01b2c0c0    VALS: 0x01b2c060    VALT: 0x01b2c000
VALU: 0x01b2bfa0    VERS: 1.4
value = 0 = 0x0
                 (o -)
--------------oOO-(_)-OOo-------------------------------------------
 Martin Pieck              |     *           *               *   \\
 MS H820, SNS-4, LANL      | *        *        /\   *            =))
 Los Alamos, NM 87545, USA |   * /\        *  /  \    /\  /\     //
                           |/\  /  \/\      _/    \/\/  \/  \ *
 (505) 665-0086 office     |  \/      \  /\/              o  \   *
 (505) 665-5107 fax        |           \/     __o       </\_  \   /\
                           |     /\o_         \<      __/\     \_/
 (505) 661-7270 home       |  ^^^^^^^^^^   (()) (())    /
____________________________________________________________________
Prev: Re: [Report] EPICS R3.13.6 build on RH Linux7.3 Noboru Yamamoto
Next: Re: [Q] How to set a timestamp in a device support routine. Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: mbboRecord - more than 16 states Marty Kraimer
Next: Diff between Torando 2.1 and 2.2 Luchini, Kristi
