1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: error in caput ("caputting negative numbers")
To: Epics Tech-Talk <[email protected]>
Date: Mon, 27 May 2002 16:29:19 -0400
    Hi, everyone.  I was wondering if anyone can help me out.
I try do the following :
caput channelName.VAL -1
and get the following:
caput: invalid option -- 1
Old : channelName.VAL              0.00
if I do:
caput channelName.VAL 1
it works.
It seems that I can't use "caput" to input negative values.  What's
going on?
                                        Cheers, Vitaliy
Vitaliy Ziskin                                Tel: (617)253-9209
MIT 26-547                          http://www.lns.mit.edu/people/vziskin/
77 Massachusetts Ave
Cambridge, Ma
02139
        "For long you live and high you fly
         And smiles you'll give and tears you'll cry
         And all you touch and all you see
         Is all your life will ever be"--Pink Floyd
Re: error in caput ("caputting negative numbers") Brian McAllister
Prev: Re: Archiving when a record processes Ned Arnold
Next: Device Support for RAMdisk Jane Richards
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: error in caput ("caputting negative numbers") Brian McAllister
