Hi Kay,
another suggestion for the (withdrawn) DRLM solution:
The clamp mode should rather use the PVAL field instead of the OVAL field.
If you have a periodically scanned "ao_reject" record, due to the OROC field slowly ramping
to reach the final value VAL. Now a user writes a new value that is out of the allowed drive range.
* If the VAL field is now set to OVAL, the record would stop at the current output value, a value
that was never set by any user or application.
* If the VAL field is set to PVAL, the record would continue to drive to the last accepted value.
I think the latter is maybe the preferred "reject" behaviour.
Cheers
Andreas
Kay-Uwe Kasemir wrote:
> >I am not happy with the proposed solution.
> Oops.
> I stand corrected and withdraw the proposed DRLM field.
> >That doesn't mean that we shouldn't do something about the problem.
> >See below for alternative solutions that reuse or rather extend the already existing
> >features....
> What followed included several important thoughts, thought
> not code. Is anybody out there not 110% busy but would have
> time to look into this?
> Meanwhile, whoever needs the described behavior and feels
> that a drive limit mode field fixes it for now:
> You can always add a new record, a copy of the AO record that includes
> the previously emailed diffs, without changing EPICS base.
> Thanks,
> -Kay
Dr. Andreas Luedeke, PSI/SLS, phone: +41-56-310-4002 fax: -4413
mailto:[email protected], http://people.web.psi.ch/luedeke
- AO: Drive Limit Mode Kay-Uwe Kasemir
- Re: AO: Drive Limit Mode Kay-Uwe Kasemir
3.14 questions Carl Lionberger
<2002>
RE: AO: Drive Limit Mode rivers
<2002>
