1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: drvAscii - termintor strategy
To: [email protected]
Date: Thu, 18 Apr 2002 09:14:50 -1000
we are having problems with the strategy used by drvAscii to find line
terminators.  We are considering changing it locally to solve our particular
problem and wonder if this would impact anybody else if the change were
propagated.
Our particular problem involves a compumotor 6000 controller.  Most of the time
it terminates strings with CR LF as requested but for some reason it sometimes
issues CR CR LF.  This completely bamboozles drvAscii which has been told to
expect CR LF.
The termination detection of drvAscii resets the string pointer of the prototype
termination string back to zero if it encounters 2nd or 3rd characters that are
not of the expected sequence. I.e. (the spaces aren't real, just for clarity):
prototype string terminator:                  CR LF
received string:                                    *      T    P   E     5
CR CR LF /0
prototype string terminator pointer:       0     0    0    0     0    0    1
0   1
next expected terminator character       CR CR CR CR CR CR LF CR LF
drvAscii then times out and the string is lost.
The solution seems to be to not reset the terminator string pointer:
CR CR LF /0
1
next expected terminator character       CR CR CR CR CR CR LF LF
Assuming the extra CR still in the string doesn't cause the subsequent scanf in
drvAscii problems, then the received string should be returned to epics (we
haven't tried it yet).
Hope the examples are clearer than mud!
So, can anyone see any problems with this proposed change, or, a better solution
cheers
Ian A Smith     Telephone: (808) 961 3756
Joint Astronomy Centre    Fax:       (808) 961 6516
660 N. A'ohoku Place        (808) 969 6591
University Park     Web: http://www.jach.hawaii.edu
Hilo
Hawaii
96720
Re: drvAscii - termintor strategy Peregrine M. McGehee
Re: drvAscii - termintor strategy Eric Williams
Re: CA "connection lost" messages Brian McAllister
Help about epics Monitor using CORBA guobao shen
Prev: strange behaviour of dbLoadtemplate Werner Portmann
Next: Re: drvAscii - termintor strategy Peregrine M. McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Help about epics Monitor using CORBA Christopher Larrieu
