1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Capturing a telnet connection event
To: [email protected]
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 11 Apr 2002 13:16:49 -0500
"J. Frederick Bartlett ([email protected])" wrote:
>   I have a situation in which I would like to know if someone has
> created a telnet connection to an EPICS IOC.  I had hoped that the IOC
> error logging facility might capture a telnet connection event;
> however, it does not.  Has anyone else encountered this problem and is
> there a solution?
You can stop access completely using shellLock(), if that's what you
really want to do.  There are also two undocumented routines mentioned in
shellLib.h called shellLoginInstall() and shellLogoutInstall() that you
can use to install your own routines to be called when someon does
{dis}connect.  I use that here at APS to output the long DOE "you must be
authorized to use this machine" message before prompting for the username
and password.
STATUS apsLoginPrompt(char *userName) {
        puts(doe_msg);
        taskDelay(1);           /* Give the above message a chance to
flush */
        return loginPrompt(userName);
In config/all/usrConfig.c the following line was added immediately after
the call to loginInit():
shellLoginInstall (apsLoginPrompt, NULL); /* install security program */
HTH,
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
Re: Capturing a telnet connection event Kay-Uwe Kasemir
Capturing a telnet connection event J. Frederick Bartlett ([email protected])
Prev: Re: Capturing a telnet connection event Ned Arnold
Next: Re: Capturing a telnet connection event Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Capturing a telnet connection event Pete R. Jemian
