Till Straumann wrote:
> From the attached diff it is not obvious to me what your fix is
> - would you mind giving me a hint, please?
This context diff of Jeff's change should help:
Index: tsFreeList.h
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/cxxTemplates/tsFreeList.h,v
retrieving revision 1.23
retrieving revision 1.22
diff -u -r1.23 -r1.22
--- tsFreeList.h 2002/01/15 20:02:45 1.23
+++ tsFreeList.h 2002/01/15 16:46:11 1.22
@@ -1,5 +1,5 @@
-/* $Id: tsFreeList.h,v 1.23 2002/01/15 20:02:45 jhill Exp $
+/* $Id: tsFreeList.h,v 1.22 2002/01/15 16:46:11 jhill Exp $
* L O S A L A M O S
* Los Alamos National Laboratory
@@ -72,8 +72,8 @@
template < class T, unsigned DEBUG_LEVEL >
union tsFreeListItem {
public:
- char pad[ sizeof ( T ) ];
tsFreeListItem < T, DEBUG_LEVEL > *pNext;
+ char pad[ sizeof ( T ) ];
template < class T, unsigned N = 0x400, unsigned DEBUG_LEVEL = 0u >
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
- RE: ca_test bus error on solaris-sparc-gnu + fix Jeff Hill
- Re: ca_test bus error on solaris-sparc-gnu + fix Till Straumann
Re: AO Record: New Drive Limit Mode? Korhonen Timo
<2002>
<2002>
