1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: AO Record: New Drive Limit Mode?
Cc: [email protected]
Date: Tue, 09 Apr 2002 12:31:43 -0400
>>> On 4/9/2002 at 11:20:03 CDT, Andrew Johnson wrote:
  > Doesn't the AO record already have a very similar behaviour controlled
  > by the IVOA field?  It's not quite the same, but do we really need this
  > kind of thing to be implemented twice?
IVOA depends on the current alarm severity being INVALID_ALARM.  Trying to
set val outside of DRVL/DRVH does not generate INVALID_ALARM.  Doing so
would be a significant behavior change in itself.
In addition, what would clear this alarm ?  The record is not really in an
INVALID state, is it ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: AO Record: New Drive Limit Mode? Andrew Johnson
Prev: Re: PCAS for WIN32 Graham Waters
Next: RE: AO Record: New Drive Limit Mode? Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: AO Record: New Drive Limit Mode? Andrew Johnson
Next: Re: AO Record: New Drive Limit Mode? Kay-Uwe Kasemir
