I have a rather odd problem with the logfile. It seems that I cannot
change where the logfile goes, even if I change the name in resource.def.
Stranger still, if I move (mv) the file to a different directory, EPICS
continues to write to that file, instead of creating a new one in the old
directory. I do not understand this behavior.
Robert
> The limit is in iocLogServer, and is controlled by the environment variable
> EPICS_IOC_LOG_FILE_LIMIT, which normally defaults to 1MB. You can either
> change the default (CONFIG_SITE_ENV in $EPICS_BASE/config is the right
> place for that) or you can set it in the environment before you start the
> logServer.
> Brian McAllister Controls Programmer/Beam Physicist
> [email protected] MIT-Bates Linear Accelerator
- Re: EPICS iocLog file size limitation Andrew Johnson
- Re: EPICS iocLog file size limitation Brian McAllister
<2002>
<2002>
