1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Error messages from tNetTask.
To: Steven Hartman <[email protected]>
Cc: Vladis Korobov <[email protected]>, EPICS tech-talk <[email protected]>
Date: Sat, 16 Mar 2002 21:58:51 -0800
Hi Steve,
thank you for analyzing the error message Slava received on his PPC.
On Friday we found a problem in our installation which might be worth mentioning:
The current setup is:
EPICSF2 is the alias name of our SUN cluster (krynfs-a and krynfs-b).
The cluster provides automatic fail over. IOCs are booting from the cluster
through the alias name.
Since we had serious performance problem (also seen as long boots for IOC's) we
called a technician and found the problem on Friday:
The SUN cluster is connected to a Cisco switch. This switch is connected (100BT)
to a 3-COM switch which connects (100BT) to a 3-COM corebuilder and this way to
our FDDI backbone. The connection (100BT) 3-COM 3-COM has to be kept because this
is the only one proven to work properly with 100BT.
The problem:
The 3COM is of the year 1996 - Cisco from 2001 ;-()
Auto negotiation of the full/half duplex functionality between the two is seen
differently:
3-COM Full duplex / Cisco Half duplex -> must be a problem! In this case the
bandwidth dropped to 10% with lots of collisions.
The solution: manually setting the Cisco to Full duplex - works.
So be aware if you connect old equipment with new stuff - they might not
understand each other!
Matthias
begin:vcard
n:Clausen;Matthias
tel;pager:FAX-personal : 49-40-8994-3256
tel;cell:-49-1759346253
tel;fax:-49-40-8998-4388
tel;home:+49-4105-669090
tel;work:-49-40-8998-3256
x-mozilla-html:TRUE
url:http://www.desy.de/~claus
org:DESY;MKS-2 / Kältekontrollen
adr:;;Notkestrasse 85;Hamburg;;22607;Germany
version:2.1
email;internet:[email protected]
title:Wissensch. Mitarbeiter/ Information System Manager
fn:Matthias Clausen
end:vcard
Re: Error messages from tNetTask. Steven Hartman
Prev: drvAbDf1 Pedro Gigoux
Next: RE: drvAbDf1 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Error messages from tNetTask. Steven Hartman
Next: drvAbDf1 Pedro Gigoux
