1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Iocsh with win32. Bad soft-record support?
To: EPICS tech-talk <[email protected]>
Date: Wed, 30 Jan 2002 17:11:53 -0600 (CST)
re...,
>If your database has more than one macro, then the
>syntax could be, for example:
>   dbLoadRecords
>"ipDevApp/Db/serial_OI_block.db","P=iad:,N=:b6,C=0,IPSLOT=b,CHAN=6", "/db/dir"
>where P, N, C, IPSLOT, and CHAN are used in the
>ipDevApp/Db/serial_OI_block.db file as variable
>parameters to be defined at the time dbLoadRecords
>is called.  The last parameter, "/db/dir", is an
>optional reference to a directory which contains the path
>to the database file.  In this case, the file is
>located at full path
>    "/db/dir/ipDevApp/Db/serial_OI_block.db"
>Pete Jemian
>UNICAT
Careful...
That last argument is not supported in the standard dbLoadRecords
command built in EPICS base.  It's only supported in the local copy
of dbLoadRecords (also dbLoadTemplate) in the synchrotron-beamline
software package, synApps.
For completeness, I added this argument when support for automatically
generated soft links was deleted from the EPICS make rules, with the
result that loading lots of databases from lots of different share
directories turned st.cmd into a 'cd' spaghetti.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Prev: Re: Iocsh with win32. Bad soft-record support? Pete R. Jemian
Next: CA client library and Connection handler Adam Jon DeGrush
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Iocsh with win32. Bad soft-record support? mooney
