epics> dbLoadRecords "dbExample1.db", "HORST" Error Last token ")" input line: record(ai, "$(user):aiExample") in: path "." file dbExample1.db line 1 Looks like you are on the right track. Try this, instead: dbLoadRecords "dbExample1.db", "user=HORST" ^^^^^ This tells the macro expander in dbLoadRecords which macro parameter gets the value "HORST". If your database has more than one macro, then the syntax could be, for example: dbLoadRecords "ipDevApp/Db/serial_OI_block.db","P=iad:,N=:b6,C=0,IPSLOT=b,CHAN=6", "/db/dir" where P, N, C, IPSLOT, and CHAN are used in the ipDevApp/Db/serial_OI_block.db file as variable parameters to be defined at the time dbLoadRecords is called. The last parameter, "/db/dir", is an optional reference to a directory which contains the path to the database file. In this case, the file is located at full path "/db/dir/ipDevApp/Db/serial_OI_block.db"
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
