1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: VXI shared memory transfer
To: [email protected]
Date: Fri, 25 Jan 2002 16:56:13 -0700
I am writing device support for a message-based VXI module that supports two modes of data transfer:
(1) Via a message, specifically through the SCPI "TRACE #" command. This is too slow -- 1000 words takes 30 seconds.
(2) Via shared memory, using the SCPI "SMEM" command. The documentation shows an example using the VISA viMoveAsync routine, but I believe there is no VISA library for EPICS.
Can anyone give me pointers on writing a routine using shared memory transfer? The VXI slot-0 controller is a hkbaja60 module.
Re: VXI shared memory transfer Kate Feng
RE: VXI shared memory transfer Jeff Hill
Prev: Re: Sequencer Problems Nicholas DiMonte
Next: VME Crate Bridges Eric Bjorklund
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: sequencer task deletion failure Brian McAllister
Next: Re: VXI shared memory transfer Kate Feng
