1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: how to handle periodic bad readings and alarms
To: "'Geoff Savage'" <[email protected]>, [email protected]
Cc: "Mackenzie, Ronald R." <[email protected]>, "Laznovsky, Michael" <[email protected]>
Date: Fri, 18 Jan 2002 10:02:26 -0800
Hi Geoff,
> One suggestion to handle
> these situations was to only signal an error afer N number of bad
> readings in a row.  Has anyone attempted to handle this
> situation with EPICS?  Any suggestions?
I know you don't use cmlog, but we use a special version of cmlog
throttling for situations like this where you just want to prevent
the error log from being flooded until the problem is resolved.
The special throttling allows on-the-fly add/remove message throttling
based on a substring of the text being logged.  Right now, one has
to login to the ioc and type a command at the prompt.  We plan to
provide an EPICS interface (subroutine records) for throttling
from an EPICS display.
Anyway, Jie Chen is considering adding this feature into the next
version of cmlog.  Mike Laznovshy and Ron MacKenzie did the work
and have documentation with more detail:
Programmer's Guide:
http://www.slac.stanford.edu/grp/cd/soft/cmlog/slac_cmlog_throttle.html
Requirements:
http://www.slac.stanford.edu/grp/cd/soft/cmlog/cmlog_throttling_needs.html
Stephanie Allison
Prev: IOC mesage at startup john sinclair
Next: caTCL with R3.14 and Linux Benjamin Sailer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: how to handle periodic bad readings and alarms Geoff Savage
Next: IOC mesage at startup john sinclair
