1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA Client Diagnostic Message
To: "'john sinclair'" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Wed, 16 Jan 2002 16:42:17 -0700
John,
This message is generated when db_put_field() return -1. Since it does
not return any other failure status that's the full extent of the
diagnostics CA can supply.
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Tuesday, January 15, 2002 3:54 PM
> To: tech talk
> Subject: CA Client Diagnostic Message
> What does this mean?
> CA.Client.Diagnostic..............................................
>     Message: "Could not perform a database value put for that channel"
>     Severity: "Warning" Context: "detected by: 192.168.18.57:5064 for:
> test:quad1Focus - with request chan=test:quad1Focus op=1
>                   data type=DBR_DOUBLE count=1"
> Doing a put to a channel causes the above although the put succeeds.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362   865-574-1268 (fax)
CA Client Diagnostic Message john sinclair
Prev: Re: CA Client Diagnostic Message Marty Kraimer
Next: Record Reference Manual / calcout record description Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: search the JAVA extensions for EPICS CA guobao shen
