1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA Client Diagnostic Message
To: Marty Kraimer <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 16 Jan 2002 08:51:01 -0500 (EST)
On Wed, 16 Jan 2002, Marty Kraimer wrote:
> john sinclair wrote:
> > What does this mean?
> > CA.Client.Diagnostic..............................................
> >     Message: "Could not perform a database value put for that channel"
> >     Severity: "Warning" Context: "detected by: 192.168.18.57:5064 for:
> > test:quad1Focus - with request chan=test:quad1Focus op=1
> >                   data type=DBR_DOUBLE count=1"
> > Doing a put to a channel causes the above although the put succeeds.
> > John Sinclair
> > [email protected]
> > Oak Ridge National Lab
> > 865-576-6362   865-574-1268 (fax)
> This message can be generated because
> 1) A dbPut returned an error.
> 2) The put succeeded but dbProcess returned an error.
> What is the record type?
> Is it processed because of the put?
> Marty Kraimer
This is an ao record using SoftChannel device support
out-linked to a constant.
The problem appears to be that
    dbPutLink( &pao->out, DBR_DOUBLE, &pao->oval, 1 );
in the soft device support code returns an error for a constant
link.
How do I say
  if ( "link type is a constant" ) {
using the proper CA macros/structures?
John Sinclair
[email protected]
Re: CA Client Diagnostic Message Marty Kraimer
Prev: Re: CA Client Diagnostic Message Marty Kraimer
Next: Re: CA Client Diagnostic Message Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
