1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Software Licensing; the GNU GPL and EPICS
Cc: Korhonen Timo <[email protected]>, tech talk <[email protected]>
Date: Wed, 19 Dec 2001 10:12:15 -0500 (EST)
So, I believe that the structure of edm complies with this idea.
> > ... The ordinary
> > General Public License therefore permits such linking only if the
> > entire combination fits its criteria of freedom.
But, do you think that the license statement should be LGPL, BSD,
or perhaps something else? I do feel the GPL "linking" issue is subject
to some degree of interpretation.
John
On Tue, 18 Dec 2001, Andrew Johnson wrote:
> john sinclair wrote:
> > I thought you could take any piece of GPL code and do anything
> > you want with it if you do not distribute it.
> True, my point 3, but see below.
> > Also, I thought I could write this code and distribute it as GPL:
> As long as you don't give away binaries or include any code copied from a
> GPL app you *might* be OK.  Anyone who creates an RPM or some other binary
> distribution of such an application would definitely be breaking the terms
> of the GPL, the EPICS license, or possibly both.
> One question that nobody can answer (because the courts would probably
> have to rule on this) is whether it's legal to actually load a program
> that links together GPL and non-free software, because such a combination
> involves the act of copying.  The GPL contains no explicit language about
> this, but the LGPL does which indicates what the FSF think the answer is:
> > When a program is linked with a library, whether statically or using
> > a shared library, the combination of the two is legally speaking a
> > combined work, a derivative of the original library. The ordinary
> > entire combination fits its criteria of freedom. The Lesser General
> > Public License permits more lax criteria for linking other code with
> > the library.
> - Andrew
> Perfection is reached, not when there is no longer anything to add,
> but when there is no longer anything to take away.
> - Antoine de Saint-Exupery
John Sinclair
[email protected]
Oak Ridge National Lab
865-576-6362   865-574-1268 (fax)
Re: Software Licensing; the GNU GPL and EPICS Andrew Johnson
Prev: Error messages wuth IP-488, VIPC616 and PPC604 Mark Rivers
Next: Re: Software Licensing; the GNU GPL and EPICS Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Software Licensing; the GNU GPL and EPICS Andrew Johnson
