Now Channel Archiver is running on our HP-UX 11 machine. What I have done is 1) add the following lines in CONFIG.Host.hppa8k (I use hppa8k in stead of hp700) in base/config. ARCH_DEP_CFLAGS += -D_HPUX_SOURCE -DHP_UX ARCH_DEP_CFLAGS += -D_POSIX_C_SOURCE=199506L ARCH_DEP_CXXFLAGS += -D_HPUX_SOURCE -DHP_UX ARCH_DEP_CXXFLAGS += -D_POSIX_C_SOURCE=199506L 2) and also add similar lines in Make.pth and Makefile.Host files in Channel Archiver directories appropriately. 3) rebuild everything in base and Channel Archiver. 3') For gcc2.95.3, I needed to put #include <new> when we got the error message: /usr/local/lib/gcc-lib/hppa2.0w-hp-hpux11.00/2.95.3/include/new:28:`operator new' takes type `size_t' as first parameter from the compiler. With gcc2.95.3, the code: #include <list> or #include <list> #include <new> create the message mentioned above. However, #include <new> #include <list> seems work OK.
for this compilation. Thanks again, Noboru KEKB control group KEK, JAPAN Thomas Birke wrote: At 09:09 PM 12/6/2001 +0900, Noboru Yamamoto wrote:
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
