1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ISO time format for tsStampToText
To: "Peregrine M. McGehee" <[email protected]>
Cc: [email protected]
Date: Thu, 06 Dec 2001 10:51:12 -1000
Hi all,
In the astronomy world FITS format is common, and uses timestamps
that start the same but are only the first 19 characters.
If a suggestion like Peregrine's gets implemented, can this
have an optional cutoff at the integer seconds?
At the JAC we currently have this implemented 2 ways, the older
being in code, the newer one with a stringin in bc635 time card
device support (Nick may correct me if I got this completely upside
down).
Aloha,
Maren
Peregrine M. McGehee wrote:
> At the Sloan Digital Sky Survey we are moving the timestamp
> formats for all observing software (both EPICS and non-EPICS)
> to that of ISO 8601 (http://www.w3.org/TR/NOTE-datetime).
> I propose adding an option TS_TEXT_ISO to base/src/libCom/tsSubr.c:tsStampToText(). Lines beginning with
> an asterisk are copied from the R3.13.5 source code.
> *       The required size of the caller's text buffer depends on the type
> *       of conversion being requested.  The conversion types, buffer sizes,
> *       and conversion formats are:
> *       TS_TEXT_MONDDYYYY  32   Mon dd, yyyy hh:mm:ss.nano-secs
> *       TS_TEXT_MMDDYY     28   mm/dd/yy hh:mm:ss.nano-secs
>         TS_TEXT_ISO        36   YYYY-MM-DDThh:mm:ss.nano-secsTZD
>         (eg 1997-07-16T19:20:30.123456789+01:00)
> where:
>      YYYY = four-digit year
>      MM   = two-digit month (01=January, etc.)
>      DD   = two-digit day of month (01 through 31)
>      hh   = two digits of hour (00 through 23) (am/pm NOT allowed)
>      mm   = two digits of minute (00 through 59)
>      ss   = two digits of second (00 through 59)
>      nano-secs    =  digits representing a decimal fraction of a second
>      TZD  = time zone designator (Z or +hh:mm or -hh:mm)
> *       For any of the formats, the fractional part of the time (represented
> *       as `nano-secs' above) is variable length.  If the usec and nsec part
> *       of the time are both zero, only milli-seconds will be printed; or
> *       else if the nsec part is zero, only milli-seconds and micro-seconds
> *       will be printed.
> Aloha,
>         Peregrine
> Peregrine M. McGehee    [email protected]      (505) 667-3273
> Sloan Digital Sky Survey / Spallation Neutron Source
> MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
Re: ISO time format for tsStampToText Peregrine M. McGehee
Prev: ISO time format for tsStampToText Peregrine M. McGehee
Next: Re: ISO time format for tsStampToText Peregrine M. McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
