Vladis,
You will need to move up to EPICS R3.13.5 to use Tornado II.
Tornado II has a new IP kernel. The network interface query
interface was not backwards compatible and so changes were
required in CA. EPICS R3.13.5 will work with either
Tornado II or Tornado I depending on which version it was built
against. You will need to completely rebuild EPICS base.
Jeff
> -----Original Message-----
> From: Vladis Korobov [mailto:[email protected]]
> Sent: Wednesday, November 28, 2001 4:31 AM
> To: [email protected]
> Subject: CA online suspended diring EPICS initialization.
> Hi everybody,
> I work with Epics R3.13.1 for PPC (MVME2306). I installed the second Ethernet
> interface board (TPMC880). Since the driver delivered with the board was
> developed under Tornado 2.0, I switched also to Tornado 2.0, vxWorks 5.4
> (previously I worked under Tornado 1.0.1, vxWorks 5.3). I've made all the
> necessary changes in vxWorks image to add the second interface as "dc"
> unit 1 (as it was recommended by the board developers).
> I changed the default port number for CA by
> 'putenv("EPICS_CA_SERVER_PORT=6025")' shell command before the EPICS
> initialization.
> Just for testing I downloaded a database consisting of the only waveform
> record. The EPICS initialization didn't finish properly. I had the following
> messages after iocInit:
> > iocInit
> > ### @(#)EPICS IOC CORE
> > ### @(#)Version R3.13.1..0 $$Date: 1999/11/09 09:47:55 $$
> > Starting iocInit
> > CAC: net intf flags fetch for failed
> > value = 0 = 0x0
> > iocInit: All initialization complete
> > data access
> > Exception current instruction address: 0x0018e7f4
> > Machine Status Register: 0x0000b030
> > Data Access Register: 0xcc576950
> > Condition Register: 0x22000042
> > Data storage interrupt Register: 0x40000000
> > Task: 0x19ed0a8 "CA online"
> > filename="../taskwd.c" line number=175
> > task 19ed0a8 CA online suspended
> Then in some while I got:
> > 0x1bbd0e8 (tNetTask): arptnew failed on 83a970bd
> I didn't attach still the second interface.
> I rebooted the PPC using unchanged vxWorks image. But with the same
> result. What could be the cause of such behaviour?
> Thank you in advance for any advice or help,
> V.Korobov
- CA online suspended diring EPICS initialization. Vladis Korobov
Channel Archiver on HP-UX 11.0 Noboru Yamamoto
Re: Channel Archiver on HP-UX 11.0 Thomas Birke
<2001>
Where can I find the caMath? guobao shen
<2001>
