Geoff Savage wrote: Hi, We occasionally encounter this message on our IOCs. 1) This message, as pointed by Andrew, one of our terminal server responds to the CA search UDP message at port 5064 and sends a NON-epics reply to the IOC which send out the CA search UDP message. Although we have several terminal servers of same type, only one of them causes this symptom. 2) Usually, it indicates there is unresolved channel connection on this IOC. So we have check channel connection status on this IOC. 3) I believe the program output this message has memory leak. So if you leave this message long enough, this would cause low memory situation, according to my experience. Regards, Noboru Yamamoto KEKB control group KEK, JAPAN
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
