1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: The "scanppl" command only works once
To: [email protected]
Cc: [email protected], [email protected]
Date: Mon, 12 Nov 2001 11:44:24 +0000
"J. Frederick Bartlett ([email protected])" wrote:
>   I have encountered a peculiar problem. The EPICS "scanppl" command
> (function) can only be executed once and generate output. The second
> and succeeding executions produce no output. This is true both for the
> console port and for telnet connections.
>   Now it gets interesting. If the telnet connection is terminated and
> then reestablished, the "scanppl" command works again (both for the
> telnet and console port connection) but still only once. Also, we see
> this only for our PPC platforms (MVME2301 and MVME2304); the MVME162
> processors allow multiple executions of "scanppl".
>   We are currently using version R3.13.4 of EPICS. Anyone have an
> explanation?
    We are running 3.13.4 on PPC's and mv167's and don't see this
problem. We can execute scanppl as many times as we like
     Regards
      Chris Mayer
Observatory Sciences Ltd.          Email: [email protected]
William James House                Tel: 44 - (0)1223 - 508257
Cowley Road,                       Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK             http://www.observatorysciences.co.uk
The "scanppl" command only works once J. Frederick Bartlett ([email protected])
Prev: Re: et_wish help requested Andy Foster
Next: Re: VxWorks on Linux Ralph . Lange
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: The "scanppl" command only works once J. Frederick Bartlett ([email protected])
Next: RE: The "scanppl" command only works once Kevin Tsubota
