1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: porting record to 3.13.4
To: Pedro Gigoux <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 22 Oct 2001 13:27:21 -0500
Pedro Gigoux wrote:
> Hi,
> I'm porting a record support routine from EPICS 3.12.3 to 3.13.4 and
> found calls to the following routines that are no longer supported:
>         status = recGblPutFastLink (&(pmr->dstl), (void *) pmr,
>                         &(pmr->dsta));
>         status = recGblInitFastInLink (&(pmr->dbgl),(void *) pmr,
>                         DBR_ENUM, "DBUG")
>         status = recGblInitFastOutLink (&(pmr->dstl),(void *) pmr,
>                         DBR_LONG, "DSTA");
> DSTL and DBGL are an output link and input link respectively. Can
> someone give me a hint on what are the routines I'm supposed to use now
> and how the calling sequence should look like?
> Thank you,
> Pedro Gigoux
> Gemini Observatory
The release notes state:
      Changes to recGbl and database access link routines.
            All code calling these should be removed. They are no longer needed.
            recGblGetFastLink
            recGblPutFastLink
            dbFastLinkGet
            dbFastLinkPut
            recGblGetLinkValue
            recGblPutLinkValue
            These are replaced by
            dbGetLink dbPutLink
            long dbGetLink(struct db_link *,short dbrType,
                    void *pbuffer,long *options,long *nRequest);
            The last two arguments can be 0. options=0 means no options.
nRequest=0 means scalar, i.e. retrieve one
            value.
            long dbPutLink(struct db_link *,short dbrType,
                    void *pbuffer,long nRequest);
            dbCaAddInLink
            dbCaAddOutlink
            dbCaGetLink
            dbCaPutLink
            The Add routines are no longer needed. The Get/Put routines are
replaced by dbGetLink/dbPutLink.
Marty Kraimer
porting record to 3.13.4 Pedro Gigoux
Prev: porting record to 3.13.4 Pedro Gigoux
Next: embedded linux experiences Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: porting record to 3.13.4 (part 2) Pedro Gigoux
