1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 3.14 on Linux
To: Eric Norum <[email protected]>
Cc: Ian A Smith <[email protected]>, [email protected]
Date: Mon, 24 Sep 2001 13:58:26 -0500
Eric Norum wrote:
> Ian A Smith wrote:
> > I'm just about to start an epics project and wonder how advisable it
> > would be to try and run 3.14 under Linux.  The only hard records
> > required would be an analogue with dev/drv support to talk to the serial
> > port of the pc.  All other records would be soft.  I also need dm
> > screens and remote CA.
> How do you plan to communicate with the hardware?  Linux allows
> user-level in/out instructions which makes basic device access very
> simple.  You need only supply a setuid-root wrapper around your
> application to gain access to the range of I/O ports you need.
As he's only using serial ports, he should be able to just open the
relevent /dev/ttySn port from user mode, thus even an suid wrapper may be
unnecessary.
I think this would be an ideal project for 3.14.  You might want to wait
for the first Beta release which is supposed to be coming out Real Soon
Now[TM], but you could start looking at the Linux end of your serial
driver in the meantime.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
3.14 on Linux Ian A Smith
Re: 3.14 on Linux Eric Norum
Prev: Re: 3.14 on Linux Matthieu Bec
Next: serial stuff on r3.14 Allan Honey
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: 3.14 on Linux Eric Norum
Next: Re: 3.14 on Linux Matthieu Bec
