Pierre-André Amaudruz wrote:
> -> ld < ComLibrary.o
> Undefined symbol: sntpcTimeGet (binding 1 type 0)
You need to add INCLUDE_SNTPC to your vxWorks build to get the SNTP client
stuff that we're now using.
> What about the "no compiler support" comment for this exception, am I
> still missing some
> components in the kernel?
I'm not sure about that, but fix the other problem first. You may also
need INCLUDE_CPLUS_STRING which I think incorporates the standard C++
exception classes.
> Does my command sequence contain the minimum setup for getting the CA to
> run?
I'm not sure, but I think you have to load munched libraries now or C++
static constructors and destructors won't be run. Have a look at what the
example application does to generate a single library to be loaded
containing all the necessary object files.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
- CA package(R3-14) on VxWorks/PPC604 Pierre-André Amaudruz
RE: CA package(R3-14) on VxWorks/PPC604 Jeff Hill
<2001>
<2001>
